Is it possible to deploy same solution twice in the same portal?
2673
09-13-2019 10:55 AM
HushamMohamed
Hello
Lets say I Daily Activity dashboard solution. I have deployed this to my Organization Portal...Now if I want to deploy the same  solution, and redeploy it as  a new solution to the same Portal then what are the ways or steps I can do this in ?
Is it one time deployment for each solution?
What if I renamed the solution name, feature name, view names?
ScottOppmann
Here is a link to a topic that will help you through this process - Frequently asked questions - ArcGIS Solutions Deployment Tool | ArcGIS Solutions
HushamMohamed
Thank you Scott,
Yes I came across that article! but that will overwrite all of my Existing hosted Feature , please correct me if I am wrong.
ScottOppmann
No, it will not overwrite the feature layers.  It will deploy a second copy of the entire solution (layers, maps, and apps).
HushamMohamed
Thank you,
it failed to create Feature Services.
failed to add Daily Activity Dashboard.
