Remove thousands separators from a field in a hosted table?
783
09-09-2019 09:57 AM
KrisReinertson1
Is there a way to remove thousands separators from a hosted table? I know that this can be done with popup config for feature services, but is there a similar way to remove thousands separators so they don't appear in the data for a field for hosted tables?
RobertBorchert
Honored Contributor
well if the data from the hosted table is in a text field simply remove the commas,
What format are the external tables in.  Typically Info Tables do no use the separators.
If the tables are in Excel you may be able to change the formatting of the excel table to no use separators.
Duncn4040
Did you ever find a solution for this? I'm having the same issue?
