Are they 10 questions or one question in a repeat?
If 10 questions it will be some work.
Add 2 hidden fields with a calculation of if(group1value,1,0) then make sure to set the bind:type column to int. Second one is if(group2value,1,0)
Then make a final field to add all 10 of the above fields up. So q1count+q2count+etc bind this to int also.
If you are using a repeat then its easier.
Then make a final field to add all 10 of the above fields up. But not all you need is sum(q1count) and sum(q2count). bind this to int also.
