Cannot find module 'esri/Map' in JS from TypeScript
2144
09-05-2019 04:06 AM
ShanmugapriyaL
I have been trying to start working on the custom widget using TypeScript. So I have followed the example from here
Import statement in main.ts file.
I was facing the import statement problem.
Solved the above issue by changing the export option in index.d.ts
My tsconfig.json file,
After compiling the ts file, I am trying to recover the issue in main.js file,
My main.js file,
Getting an error while compiling js file,
Browser window:
The "Esri/Map" module is cannot be founded in the JS file. If I am missing anything on this above code, kindly comment to solve this issue.
Thank you in advance.
