Charts - ArcGIS Pro
299
08-30-2019 08:31 AM
ErinLeFevre1
I've created a profile graph depicting elevation change and I noticed that when I resize the window, the "vertical exaggeration" of the line changes. Is there a way to "lock" the graph so the VE doesn't change? Even better, is there a way to set the vertical exaggeration of line feature beforehand and then lock the window?  For background, I started with an xyz file of an "elevation profile" that was drawn in another program. I imported the data into ArcGIS Pro as xy data and then converted the points to a line feature and added it to a Scene where I then created a profile graph.
