spatial join
1842
5
08-23-2019 11:28 AM
bobwright
Greetings,
Does Collector does spatial joins with underlying layers? In my searches I haven't been able to confirm or deny. Thanks.
Bob
Kylie
by Esri Regular Contributor
Hi Bob -- Could you clarify a bit what you are looking to do? For example, you can use the Join Features tool in ArcGIS Online or ArcGIS Enterprise, save the result as a new hosted layer view, and then use that view in maps in Collector. However, these layers will be read-only and can't be taken offline.
(Source: Add editable layers to a map, step 7 - in Make a map—Collector for ArcGIS | ArcGIS
Esri Education Team
bobwright
Hi Kylie,
I’m wondering if Collector can do a Spatial Join, where attributes of interest from an underlying layer are added to table of the newly-created feature.
Bob
Kylie
No, this isn't something Collector supports. I'd recommend using other ArcGIS tools to do this once back in the office.
Esri Education Team
bobwright
OK. Thanks.
DougBrowning
MVP Esteemed Contributor
Relationships classes work great for this.  Link the two tables instead of doubling up the attributes.
