identify change in row sequence
1899
08-22-2019 09:00 AM
CliveCartwright
I'm trying to find a way of adding <Null> to a record when there a change in the data sequence on another field attribute...?
I've been trying to adapt this code to achieve this, but I'm struggling.
import arcpy
from arcpy import da
vertices = "dataset"
#set firstRow variable to true
firstRow = True
with arcpy.da.UpdateCursor(vertices, ["Shape", "Line_ID", "angle"]) as cursor:
for row in cursor:
 name2 = row[1]
#check if its the first row
 if firstRow == True:
 name1 = name2
 #set firstrow to false
 firstRow = False
 continue
 row[2] = str(name1 - name2)
 name1 = name2
 cursor.updateRow(row)
The result should be something like this:
I'm rather new to UpdateCurser, so, generally don't know how it works.
JoshuaBixby
MVP Esteemed Contributor
Does this work for you?
import arcpy
firstRow = True
    vertices,
    ["Line_ID", "angle"]
    sql_clause=(None, "ORDER BY LINE_ID, OBJECTID")
) as cursor:
    lid_prev, ang_prev = next(cursor)
    cursor.updateRow([lid_prev, None])
    for lid, ang in cursor:
        if lid != lid_prev:
            cursor.updateRow([lid, None])
        lid_prev = lid
JoshuaBixby
import arcpy
firstRow = True
    vertices,
) as cursor:
        if lid != lid_prev:
        lid_prev = lid
CliveCartwright
Much appreciated Joshua. Thank You.
JoshuaBixby
If my suggestion worked, please mark it correct to close the question.
