Microsoft Visual C++ runtime error - ArcGIS online basemap loading
2127
08-19-2019 12:50 PM
ChristopherGlover
I am running ArcGIS 10.0 on a work computer. Recently, when attempting to load the USA Topo Maps from ArcGIS Online basemaps, I am receiving the "Microsoft Visual C++ Runtime Library" error, thereby cancelling the basemap addition. This only seems to happen when I try to add the USA Topo maps. I can download the gray scale basemap, world imagery, etc. just fine. I can also drag the USA Topo basemap from previous projects in which it was already added, and it works fine with my new projects.
I have uninstalled and reinstalled Microsoft Visuall C++, as well as ran multiple registry cleaning scans and everything seems in order. Does anyone have any idea why I am getting this error message and how to fix the problem? I have found a temporary workaround, but would like to resolve the issue.
Tags (1)
George_Thompson
Esri Notable Contributor
Can you try this workflow on a supported version of ArcMap?
I see the note that if you drag it from other old MXDs that it works fine.
What is the exact error being produced? Need more details on that.
--- George T.
ChristopherGlover
Error Message Snip
George_Thompson
Uh, ok. That is not a helpful error.
I would recommend you contact Esri technical support. The one caveat is that v10.0.x - v10.2.x are no longer supported. You would have to test with at least v10.3.1 with support.
Is there a reason for being on v10.0.x?
--- George T.
