Change Basemap with button
1775
5
08-16-2019 06:43 AM
jaykapalczynski
Honored Contributor
Simply trying to change the basemap with a click of a button any it does not seem to be working....any thoughts?
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import QtQuick 2.9
import QtQuick.Controls 1.4
import QtQuick.Controls.Styles 1.4
import Esri.ArcGISRuntime 100.5
import QtQuick.Layouts 1.1
Item {
    signal previous(string message)
    property string basemapId: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"
    MapView {
        Layout.fillHeight: true
        Layout.alignment: Qt.AlignTop
        width: parent.width
        height: parent.height
        property real initialMapRotation: 0
        Map {
            Basemap {
                ArcGISTiledLayer {
                    url: basemapId
                    visible: true
    Row {
        anchors {
            bottom: parent.bottom
            left: parent.left
            right: parent.right
            margins: 5 * scaleFactor
            bottomMargin: 50 * scaleFactor
        spacing: 5
        Button {
            text: "Switch Basemap"
            onClicked: {
                console.log("changing basemamp");
                basemapId = "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer"
                baseMap.load(basemapId);
jaykapalczynski
Honored Contributor
I changed my code to this and everything works fine....
Thanks Harsh from ESRI
It was in reference to this example: https://github.com/Esri/arcgis-runtime-samples-qt/tree/master/ArcGISRuntimeSDKQt_QMLSamples/Maps/Cha...
that used a combobox and its index to find the correct map to load....As I was using a button I had to create that index and decided to do so with an If then statement and an index number I created to loop through the maps.
Anyone know a better way to do this?
import QtQuick 2.9
Item {
    property string basemapId: ""
    property int basemapindex: 1
    MapView {
        width: parent.width
        Map {
            initialViewpoint: viewPoint
            // Set the initial basemap to Topographic
            BasemapTopographic {}
        } // END OF MAP
    } // END OF MAPVIEW
    ListModel {
        ListElement { text: "Topographic"; map: "BasemapTopographic" }
        ListElement { text: "Streets (Vector)"; map: "BasemapStreetsVector" }
        ListElement { text: "Streets - Night (Vector)"; map: "BasemapStreetsNightVector" }
        ListElement { text: "Imagery with Labels (Vector)"; map: "BasemapImageryWithLabelsVector" }
        ListElement { text: "Navigation (Vector)"; map: "BasemapNavigationVector" }
        //ListElement { text: "Streets"; map: "BasemapStreets" }
        //ListElement { text: "Imagery (Raster)"; map: "BasemapImagery" }
        //ListElement { text: "Imagery with Labels (Raster)"; map: "BasemapImageryWithLabels" }
        //ListElement { text: "Dark Gray Canvas (Vector)"; map: "BasemapDarkGrayCanvasVector" }
        //ListElement { text: "Light Gray Canvas (Raster)"; map: "BasemapLightGrayCanvas" }
        //ListElement { text: "Light Gray Canvas (Vector)"; map: "BasemapLightGrayCanvasVector" }
        //ListElement { text: "OpenStreetMap (Raster)"; map: "BasemapOpenStreetMap" }
        //ListElement { text: "Oceans"; map: "BasemapOceans" }
    Row {
        anchors {
            left: parent.left
            right: parent.right
        spacing: 5
        Button {
            text: "Topo"
            onClicked: {
                if (basemapindex == 1) {
                    changeBasemap(cbItems.get(1).map);
                    basemapindex = 2
                    buttontext.text = "Streets"
                } else if (basemapindex == 2){
                    changeBasemap(cbItems.get(2).map);
                    basemapindex = 3
                    buttontext.text = "Street Night"
                } else if (basemapindex == 3){
                    changeBasemap(cbItems.get(3).map);
                    basemapindex = 4
                    buttontext.text = "Imagery Labels"
                } else if (basemapindex == 4){
                    changeBasemap(cbItems.get(4).map);
                    basemapindex = 0
                    buttontext.text = "Navigation"
                } else if (basemapindex == 0){
                    basemapindex = 1
                    changeBasemap(cbItems.get(0).map);
                    buttontext.text = "Topo"
                function changeBasemap(type) {
                    map.basemap = ArcGISRuntimeEnvironment.createObject(type);
            } // End of OnClicked
        } // End of Button
    } // End of Row
    ViewpointCenter {
        center: Point {
            //x: -13630484
            //y: 4545415
            x: -8622115
            y: 4513608
            spatialReference: SpatialReference {
                wkid: 102100
        targetScale: 3000000
jaykapalczynski
Honored Contributor
I found a way and did it like this....if anyone knows a smoother way please chime in...
import QtQuick 2.9
Item {
    MapView {
        width: parent.width
        Map {
        } // END OF MAP
    } // END OF MAPVIEW
    Component.onCompleted: {
         loadWebMap(cbItems2.get(0).item)
    // Javascript Functions
    // Function to load webmap
    function loadWebMap(webmapitemid){
        var organizationPortalUrl = "http://arcgis.com/sharing/rest/content/items/";
        var webmapUrl = organizationPortalUrl + webmapitemid;
        var newMap = ArcGISRuntimeEnvironment.createObject("Map", {initUrl: webmapUrl, autoFetchLegendInfos:true});
        mapView.map = newMap;
    ListModel {
        ListElement { name: "Imagery hybrid w Labels"; item: "86265e5a4bbb4187a59719cf134e0018" }
        ListElement { name: "Topo"; item: "d5e02a0c1f2b4ec399823fdd3c2fdebd" }
        ListElement { name: "Topographic"; item: "931d892ac7a843d7ba29d085e0433465" }
        ListElement { name: "Streets"; item: "8bf7167d20924cbf8e25e7b11c7c502c" }
        ListElement { name: "Streets Nights"; item: "7e2b9be8a9c94e45b7f87857d8d168d6" }
    Row {
        anchors {
            left: parent.left
            right: parent.right
        spacing: 5
        Button {
            text: "Imagery"
            onClicked: {
                   loadWebMap(cbItems2.get(1).item)
                   basemapindex = 2
                   loadWebMap(cbItems2.get(2).item)
                   basemapindex = 3
                    buttontext.text = "Topographic"
                   loadWebMap(cbItems2.get(3).item)
                   basemapindex = 4
                   loadWebMap(cbItems2.get(4).item)
                   basemapindex = 0
                    buttontext.text = "Streets Night"
                   basemapindex = 1
                    buttontext.text = "Imagery"
    ViewpointCenter {
        center: Point {
            //x: -13630484
            //y: 4545415
            x: -8622115
            y: 4513608
                wkid: 102100
jaykapalczynski
Honored Contributor
My only problem now is that when I switch between them it zooms me way out ....I want to keep the user at the spot they were last zoomed to.....I guess I need to capture the current extent and put that in....not sure how to do that.  Thoughts?
jaykapalczynski
Honored Contributor
import QtQuick 2.9
Item {
    MapView {
        width: parent.width
        Map {
        } // END OF MAP
    } // END OF MAPVIEW
    ListModel {
    Row {
        anchors {
            left: parent.left
            right: parent.right
        spacing: 5
        Button {
            text: "Topo"
            onClicked: {
                    basemapindex = 2
                    basemapindex = 3
                    basemapindex = 4
                    basemapindex = 0
                    basemapindex = 1
        } // End of Button
    } // End of Row
    ViewpointCenter {
        center: Point {
            //x: -13630484
            //y: 4545415
            x: -8622115
            y: 4513608
                wkid: 102100
KeithLarson1
Hey,
I think you could do away with the if statements in the onClicked function completely. You could change it to a switch case block, or you could just use the index to get the basemap and text from the ListModel. You could either reuse the "text" field in the ListElements as the button text, or you could create a separate shorter "buttonText" field to associate the index with the button text. Then, when you click the button, you just have to grab the basemap at that index, increment the index or reset to 0 depending on the ListModel count, and set the button's text to the buttonText at that index.
import QtQuick 2.9
Item {
    MapView {
        width: parent.width
        Map {
        } // END OF MAP
    } // END OF MAPVIEW
    ListModel {
        ListElement { text: "Topographic"; map: "BasemapTopographic", buttonText: "Topo" }
        ListElement { text: "Streets (Vector)"; map: "BasemapStreetsVector", buttonText: "Streets" }
        ListElement { text: "Streets - Night (Vector)"; map: "BasemapStreetsNightVector", buttonText: "Street Night" }
        ListElement { text: "Imagery with Labels (Vector)"; map: "BasemapImageryWithLabelsVector", buttonText: "Imagery Labels" }
        ListElement { text: "Navigation (Vector)"; map: "BasemapNavigationVector", buttonText: "Navigation" }
    Row {
        anchors {
            left: parent.left
            right: parent.right
        spacing: 5
        Button {
            text: "Topo"
            onClicked: {
				changeBasemap(cbItems.get(basemapindex).map);
				if (basemapindex < cbItems.count - 1) {
					basemapindex++;
				else {
					basemapindex = 0;
				buttontext.text = cbItems.get(basemapIndex).buttonText;
        } // End of Button
    } // End of Row
    ViewpointCenter {
        center: Point {
            //x: -13630484
            //y: 4545415
            x: -8622115
            y: 4513608
                wkid: 102100
I hope this helps!
-Keith
jaykapalczynski
Honored Contributor
Awesome Keith....thanks...
