Search using related tables
898
08-14-2019 04:28 PM
GuzaloiRakhimova
I was able to do a search using related tables. What is happening is that the results appear, but when you actually click on the result it shows as "No results found for ….". So my goal is to when you search using the related table data and click on the appeared result, it should actually show in the map (zoom in the map) and locate the location in the map according to the data we typed in the search box. Which custom widget is a good toll for that?
Thanks in advance
LeoLiu1
Hi Guzaloi,
You can try the FeatureTable, it has an property 'zoomToSelection', which will zoom to selected records.
ArcGIS API for JavaScript Sandbox
