Pro 2.4 - Format all symbols Properties
4884
8
08-13-2019 10:09 AM
MatthewDriscoll
When I go to "Format all symbols" the "Layers" and "Structure" options under "Properties" are missing?
by Anonymous User
Not applicable
Hi Matthew. Are you using a Graduated renderer with a multi-symbol selection?
MatthewDriscoll
No. Unique Values.
by Anonymous User
Not applicable
Thanks. Is there more than one class? I want to see if this aligns with an existing limitation.
MatthewDriscoll
Yes,  50 States.
by Anonymous User
Not applicable
Okay thanks Matthew. It does look like this matches an item we're tracking as an equivalency issue. This is known to our development team and support has posted this at the following link where you can subscribe for updates: BUG-000108431: When formatting all symbols, the buttons to modify s..
In addition to updating you, this helps with prioritizing and tracking.
There is a related discussion concerning symbol properties:How to I remove outlines from point symbols in ArcPro?
MatthewDriscoll
Ok.  It is similar..  Also that bug is almost two years old!
DavidWheelock2
This is another major show-stopper.  I'm currently having to go back to ArcMap, create symbology there, and then import it to ArcGIS Pro.
DavidWheelock2
There was a bug created for this issue that now indicates that this has been implemented, but it has not.  I, too, am using the latest update 2.7.2.
I am still not seeing the missing features.
More here:
https://community.esri.com/t5/arcgis-pro-questions/limited-options-in-format-all-symbols/m-p/267096
