"Import Error" in PyCharm
2230
08-11-2019 07:59 PM
IliaNeudakhin
Hello! I try to do web course "Python for Everyone" and have a problem on the step "Exercise: Run Python scripts".
I can't finish "Step 4: Run a script in PyCharm", because I get an error "ImportError: DLL load failed: %1 не является приложением Win32". If translate "ImportError: DLL load failed: %1 is not a valid Win32 application".
Please, explain, what I have to do (I have 64 bit Windows 7, 64 bit ArcGIS Pro 2.4.0 and last version of 64 bit PyCharm)?
Thank you.
IliaNeudakhin
It is fixed after I remove the  'PYTHONPATH' variable with references to the ArcGIS 32-bit installation of Python.
According to this article:
import ArcPy into ArcGIS Pro error:  https://support.esri.com/en/technical-article/000019997
JoeBorgione
Can you open pycharm first, load your script into it and then run it?
IliaNeudakhin
Joe! Thank you for the reply, I fix this problem)))
