How to add predefined folder connections into favorites programmatically
2864
9
08-07-2019 07:01 PM
by Anonymous User
Not applicable
Hi Guys,
I saw a lot of sample code to add folder connection dynamically with sdk. But I got a requirement that the users want to have set of predefined folder connections into their favorite before they create the project. Is there any code snippet I can refer to?
UmaHarano
One way to accomplish this is to -
Uma
by Anonymous User
Not applicable
Thank Uma,
This is the good idea.
And also your suggestion is one of the requirement for me to do so as well together with checking the existing project's folder connection to validate.
As an additional, they also want to add those connections into favorites.
I do manage to add folder into folder connection with below code
var folderToAdd = ItemFactory.Instance.Create(folderpath);
await QueuedTask.Run(() => Project.Current.AddItem(folderToAdd as IProjectItem);
One thing I can't manage to do is that can't find a way to add the folder path into favorites and read the existing paths from favorites.
And I am thinking whether it is good way to update [profile path]\AppData\Roaming\Esri\ArcGISPro\Favorites\favorites.json file as well.
I saw the command but there is precondition mentioned in it to call that command, [esri_geodatabase_addFolderConnectionToFavoritesButton] , not sure how to use that or is that correct one as well.
What do you recommend?
UmaHarano
Hi Than
The ability to add folder connections to the "Favorites" is slated to be available with 2.5 release. But in the meantime, you can definitely re-use the esri_geodatabase_addFolderConnectionToFavoritesButton button in your customization.
Uma
by Anonymous User
Not applicable
Thank Uma,
I shall try use it and contact you when I encountered issue.
by Anonymous User
Not applicable
Hi Uma Harano‌,
May I know how to do it in 2.5, since it is released.
I tried to find it in api doco url as below reference and didn't manage to find out.
I might have missed.
ArcGIS Pro 2.5 API Reference Guide
Thank and Best Regards,
Than
UmaHarano
Hi Than,
Unfortunately this did not make it in 2.5. I will reply to this thread when I have more information.
Uma
by Anonymous User
Not applicable
Thank Uma Harano
by Anonymous User
Not applicable
Hi Uma Harano‌,
May I know whether that feature is available in 2.6 now?
by Anonymous User
Not applicable
Hi Uma Harano‌,
May I know whether that feature is available in 2.7 sdk already?
Best Regards,
Than
