Adding a custom widget to web app builder arcgis online
1490
08-02-2019 06:39 AM
SarahReasbeck
I am having difficulty adding a custom widget (popup panel) to my application on web app builder on my arcgis online account. I am following steps I have found online but I am coming up unsuccessful. Anyone have and tips on how this is done? I haven't been able to find any concrete step by step instructions.  Thank you!
Robert_LeClair
Esri Esteemed Contributor
Are you using the WebApp Builder for ArcGIS (Developer Edition) to create/add the custom widget?
Web AppBuilder for ArcGIS
DerekLaw
Hi Sarah,
Adding custom widgets to Web AppBuilder embedded in ArcGIS Online is not a supported workflow. You can use Web AppBuilder Developer Edition (which you would download locally, then connect to your ArcGIS Online organization) - add a custom widget to it, to work with your data.
Some resources:
Hope this helps,
SarahReasbeck
Yes I am using the Developer Edition.
Suzanne-Boden
Hi Sarah, I'm not sure if this is related but there's a new version of ArcGIS Web AppBuilder Developer Edition that may be impacting your experience: https://www.esri.com/arcgis-blog/products/web-appbuilder-dev-ed/announcements/web-appbuilder-for-arc...
