invalid SQL expression
865
08-01-2019 08:02 AM
NicholasDow
fromaddr_l<> 0 and MOD (" fromaddr_l ",  2)  = 1 AND toaddr_l <> 0 and MOD (" toaddr_l",  2)  = 1. Field type is Text.
Tags (1)
Egge-Jan_Pollé
Hi Nicholas,
Sounds reasonable doesn't it? The modulo operator (MOD) can only be applied to integer values.
  • MOD returns the remainder of integer_exp1 divided by integer_exp2.
  • Maybe you should use the CAST function to converts your input values to integers first. The syntax is as follows:
    CAST(exp AS data_type)
See: SQL reference for query expressions used in ArcGIS—ArcGIS Pro | ArcGIS Desktop
HTH,
Egge-Jan
