Add Tools to Favorites and Analysis Gallery
668
08-01-2019 07:09 AM
JoeBorgione
ArcGIS Pro 2.4
I must be missing something obvious, but...
If I open an ArcGIS Pro Session with Start without a template, and add specific tools to the Favorites List and or the Analysis Gallery, how can I ensure they will be there the next time I open ArcGIS Pro without a template?
Tags (1)
George_Thompson
Esri Frequent Contributor
I am not sure that it is designed that way; https://pro.arcgis.com/en/pro-app/help/projects/create-a-new-project.htm#ESRI_SECTION1_D3876767A5924...
It looks like unless you save that "template" with all the information it is forgotten when closed.
Did it work that way in ArcGIS Pro 2.3.x?
--- George T.
George_Thompson
--- George T.
JoeBorgione
Thanks George.  I know I created my own templates using my favorites in earlier versions.  I can just do that again; actually, the catalog template is a good one to 'save as' since it more or less emulates an ArcCatalog session.
KoryKramer
Esri Community Moderator
https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/customize-arcgis-pro-with-geopr... in terms of the documentation on how geoprocessing favorites work (i.e. they are project specific).
BrianWade
I find the easiest way is to create a startup project that I use that has all of my geo, tools, links and folders loaded. I then remove any stuff I dont need or want for whatever project I'm doing. that way all my stuff is there everytime.
