Is it possible to collapse multiple Layer Lists by default?
4696
5
07-25-2019 01:05 PM
MichaelRock1
I have created an aggregate Layer List widget by dragging multiple Layer Lists into one.  This creates a Layer List panel in which each list is expanded by default and given the same amount of space.  I would like to collapse all but one of the lists by default so the user is presented with a simple interface.  Is this possible?
Here is how it opens:
And this is what I want:
Thanks for any suggestions!
Mike
RobertScheitlin__GISP
Mike, sure here is how to do that in WAB 2.12.
In the themes\[chosen theme]\panels\FoldablePanel\Panel.js (line 8 added):
      createFrame: function(widgetConfig) {
        var frame;
        if (this.config.widgets && this.config.widgets.length === 1 || !this.config.widgets) {
          frame = new BaseWidgetFrame();
        } else {
          frame = new FoldableWidgetFrame({
            label: widgetConfig.label,
            openfolded: widgetConfig.folded,
            widgetManager: this.widgetManager
In the themes\[chosen theme]\panels\FoldablePanel\FoldableDijit.js (added line 23-27):
      createFoldableBtn: function() {
        this.foldableNode = html.create('div', {
          'class': 'foldable-btn',
          'role': 'button',
          'aria-label': this.headerNls.foldWindow,
          'tabindex': 0
        }, this.btnsContainer);
        this.own(on(this.foldableNode, 'click', lang.hitch(this, function(evt){
          evt.stopPropagation();
          this.onFoldableNodeClick();
        this.own(on(this.foldableNode, 'keydown', lang.hitch(this, function(evt) {
          if(evt.keyCode === keys.ENTER || evt.keyCode === keys.SPACE){
          }else if(evt.keyCode === keys.TAB && evt.shiftKey){
            evt.preventDefault();
        if(this.openfolded){
          setTimeout(lang.hitch(this, function(){
          }), 500);
In the apps main config.json (added line 11 & 19):
"groups": [
        "label": "New group",
        "widgets": [
            "uri": "widgets/LayerList/Widget",
            "version": "2.5",
            "id": "widgets_LayerList_Widget_18",
            "name": "LayerList",
            "index": 1,
            "folded": false
            "uri": "widgets/Legend/Widget",
            "version": "2.5",
            "id": "widgets_Legend_Widget_17",
            "name": "Legend",
            "index": 0,
            "folded": true
        var frame;
        } else {
          'role': 'button',
          'tabindex': 0
          }), 500);
"groups": [
        "widgets": [
            "version": "2.5",
            "index": 1,
            "folded": false
            "version": "2.5",
            "name": "Legend",
            "index": 0,
            "folded": true
MichaelRock1
Thanks Robert, that is awesome! But of course I did not explain my full environment.  I am not using Portal, but ArcGIS Online. So my only avenue to editing JSON is the AGOL Assistant site.  I did try and add the "folded": true to the configuration, but it did not have an effect.
Does that make sense? I created the app in ArcGIS Online by using the Create-> App-> Using the Web AppBuilder option.
Thanks for your help!
Mike
Michael,
  Sorry to say it will not be possible for you then. You have to be using WAB dev or portal at a minimum to accomplish this.
MichaelRock1
OK, thanks.  That's what I feared.
Mike
PiaN
how is this possible in portal without WAB dev?
