Format decimal place in ArcGIS Pro
41137
13
07-22-2019 09:19 AM
KarenHoelscher
I am trying to change the decimal place to my acres in ArcPro which is easily done in ArcDesktop (added screen shots of both). I right click on the field in Desktop go to Properties - Number format make changes. But when I try that in Pro there is NO Properties on the drop down AM I missing something. I thought I had gone here before in Pro and made this change. I'm I going to the wrong place??
MatthewDriscoll
MatthewDriscoll
Right click the field in the attribute table and open "Fields"  -> Click on the Number Format and click the three dots (...).
Laetitia_PiersPiers
Thank you so much for sharing Matthew!
KarenHoelscher
I get NO dots (. . .)
MatthewDriscoll
Double click.
TimMinter
Wow, that was some sorta un-intuitive right there.  Thanks for sharing the key to fixing ArcGIS Pro's mangling of my data, Matthew!
Hmmm, this gives me an ArcGIS Idea...
tim
NC1
I double click but get nothing. Please, Can you help me?
KarenHoelscher
Double Click is the key!!!! Thank you Matthew!!!
MatthewDriscoll
Make sure to mark the answer as correct!
LionelPlummer
Thank you as well Matthew - that was a tricky one for me as well!
