Permissions required for ArcGIS Server and attribute rules
1343
07-21-2019 07:28 PM
Marc_Graham
Hi there,
We have an ArcGIS Server install that accesses feature classes in our enterprise geodatabase using a windows domain account.  The account is explicitly given permissions on feature classes using ArcCatalog. The db is registered as a data store in Server Manager using an OS authenticated connection.  We also have a data owner account with its own schema and an SDE user/schema as per normal.
I am encountering an issue when trying to publish services (and edit in a web app) that use a database sequence to generate a unique ID as per https://community.esri.com/thread/220462-using-unique-id-using-attribute-rules
I create the database sequence using the GIS data owner, but this is not immediately available to the ArcGIS Server user.  There doesn't appear to be a way to give the ArcGIS Server user permissions on it in Arc-anything.
When I try and edit the service with the attribute rule the edits fail with an error saying the db sequence could not be found.
I have tried to give read permissions on the sequence to the ArcGIS Server user in SQL server manager, but this doesn't seem to help. Maybe I am doing it wrong.
If I register a connection to the db in ArcGIS Server manager using the gis data owner account and publish the service using that connection then everything works as I would expect, the edits work and the ID is automatically incremented.
so, tldr: do we have to publish services with attribute rules that use sequences from a data owner connection, and if not, how do we give the ArcGIS Server user the correct permissions on the sequence so the attribute rule works?
Marc
