"Create Coverage Features" does not create coverage features (Manage Oriented Imagery)
2000
07-16-2019 11:15 PM
SergeiMitakovich
Hi. I tried to repeat process in tutorial "Create an Oriented Imagery Catalog" and function "Create Coverage Features" doesn't create any features in polygon layer. It's empty. I used as default values for need fields or really populated values in point layer. No result. What could be a problem?
AmruthaJayachandran
Could you let us know the version of ArcGIS Pro(Project tab-> About) you are using as well as the version of the GP Tools (Right click the tool box, select properties)
SergeiMitakovich
ArcGIS Pro 2.4.0
Manage Oriented Imagery v1.1.1 (27th March 2019)
And I also switched between Russian localization and English localization in Windows (in Russia we use "," for separating numbers). No result
SergeiMitakovich
Today I solved to repeat the process. After my last try I uninstalled Visual Studio .Net (VS) 2015 and related components and installed VS 2017. Today I also reinstalled "Oriented Imagery Management Tools". And it's worked! I was able to complete tutorial and now I will try to repeat with my drone data. Thank you for your complicity
