A security exception occurred while trying to connect to the 'WMS' service
3434
07-11-2019 02:22 AM
VinayS
Please refer my previous question in the link given below.
https://community.esri.com/message/858968-re-issue-in-accessing-wms-layers-in-arcgis-api-31-for-silv...
I am trying to add WMS layer published on GeoServer using the code given below
var wmsLayer = new WmsLayer()
   ID = "highways:sp_health_dh",
   Url = "https://tnssdi.tn.gov.in/geoserver/wms",
   SkipGetCapabilities = false,
   Version = "1.1.1",
   Opacity = 0.7,
   DisplayName = "District Hospitals",
   Layers = new string[] { "highways:sp_health_dh" }
map.Layers.Add(wmsLayer);
When I try to run the application, received the following error.
Unhandled exception at line 159, column 14 in http://localhost:60414/epathaigis.aspx
0x800a139e - JavaScript runtime error: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.Security.SecurityException: A security exception occurred while trying to connect to the 'WMS' service. Make sure you have a cross domain policy file available at the root for your server that allows for requests from this application. If not, use a proxy page (handler) to broker communication. ---> System.Security.SecurityException ---> System.Security.SecurityException: Security error.
at System.Net.Browser.BrowserHttpWebRequest.InternalEndGetResponse(IAsyncResult asyncResult)
at System.Net.Browser.BrowserHttpWebRequest.<>c__DisplayClassa.<EndGetResponse>b__9(Object sendState)
at System.Net.Browser.AsyncHelper.<>c__DisplayClass4.<BeginOnUI>b__0(Object sendState)
--- End of inner exception stack trace ---
at System.Net.Browser.AsyncHelper.BeginOnUI(SendOrPostCallback beginMethod, Object state)
at System.Net.Browser.BrowserHttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
at ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e)
at ESRI.ArcGIS.Client.Layer.Initialize()
at ESRI.ArcGIS.Client.Toolkit.DataSources.WmsLayer.client_DownloadStringCompleted(Object sender, DownloadStringCompletedEventArgs e)
at System.Net.WebClient.OnDownloadStringCompleted(DownloadStringCompletedEventArgs e)
at System.Net.WebClient.DownloadStringOperationCompleted(Object arg)
To resolve the error, I added crossdomain.xml in the root folder where the layers are published. Still I am getting the same error.
How can I resolve the above issue?
