Embedded Survey123 Url in Creation Template
1123
07-10-2019 10:34 AM
by Anonymous User
Not applicable
I see there is a lot of talk on embedding a survey URL inside of a pop up and retrieving the GlobalID. Has anyone ever tried to do this or know if it is possible through the creation template? I have gotten this to work in the pop up, but all of the information in the pop up disappears. Through the creation template, I've gotten it to work to but when the GlobalID comes in it looks like {GlobalID} and not the number/letters. I have also tried the regex trick and adding a separate null field but still comes into the new field as {GlobalID} and won't translate to the ParentGlobalID field.
JamesTedrick
Esri Esteemed Contributor
Hi Todd,
This is more of an ArcGIS Online‌ issue, but I don't believe the creation template supports placeholders - that is for use in pop-ups.
