Custom Attribute Expression in ArcGIS Online to Show Related Table Information
8020
14
07-09-2019 11:04 AM
KieranClark
I have a map that shows international submarine cables and their landing points around the world. I have a standalone table added to my map that lists all the landing points and what cables they are associated with like so:
My list of landings is unique City/State/Country names and it's possible for more than one cable system to come to a single landing. What I want to do - and I think I have all the correct tables and data needed for this - is to create an attribute expression so that when someone clicks on a Landing Point it shows all the Cable Systems associated with that landing. Fortaleza, for instance, is associated with 14 cable systems.
I was able to do something similar in ArcGIS Pro using a Relate but I'm trying to figure out how to do the same thing in my web map. Basically what I need to do is match the "Name" field from my Landing Points layer to the "Cable_Landings_Export.City" field in my standalone table and then add all the cable system names from the "All_Cables_Table_Export.SystemName" field as a list, preferably bulleted or something and not a comma separated list.
I'm not a coder so I'm a little lost trying to work with Arcade and not sure where I should even start.
XanderBakker
Esri Esteemed Contributor
Hi Kieran Clark ,
There are a couple of things you will need to do in the expression. I assume that you have a point featureclass with the landing points and the name of the city:
  • Read out the name of the city of the landing point the user clicked on
  • Get access to the table of LandingPlusCableTable
  • Create a query using the name of the city
  • Use a filter to get all the related records from the table
  • Loop through the resulting records and construct a string with all the information you want to present
The code could look like this, but you will have to adjust the table name and fields to match your data:
var cityname = $feature["City Field Name"]; // read out the city
var sql = "City_Field_Name_in_table" + " = " + cityname; // create query
var table = FeatureSetByName($map, "Exact name of table as used in the map"); // get access to table
var related_records = Filter(table, sql); // filter the table for relevant records
var cnt = Count(related_records); // determine the number of records found
var result = "";
if (cnt == 0) {
    // no records found
    result = "No cable systems found";
} else {
    // we have related records, let's create the text to return
    result = cnt + "cable system(s) found:";
    for (record in related_records) {
        txt = TextFormatting.NewLine + " - " + record.systemname; // use the correct field name from the table
        result += txt;
return result;
KieranClark
Thanks so much for this, this is definitely a great start.
However, I keep getting "Field not found" errors and I'm not really sure what to do as it's not highlighting where things are going wrong. Let me describe the tables/layers I'm using a little more in detail with the field names.
The standalone table that has landings linked to each cable is named "LandingPlusCableTable" and has the following fields:
Cable_Landings_Export_City - This contains the name of the city where cables land.
Cable_Landings_Export_State_Province - The state or province where the city is located, shouldn't be relevant to this
Cable_Landings_Export_Country - The country where the city is located, shouldn't be relevant to this
All_Cables_Table_Export_OBJECTID - This field contains the CableID that is the unique identifier for each record in our submarine cable database.
All_Cables_Table_Export_SystemName - This field contains the name of the cable system that lands at the city
My Landing Points feature is structured as follows:
"STFLandings20180529_JOIN"
The only relevant field here should be the one that is pulled the City name: "STF_Cable_DBO_tblLanding_City" which has the alias "City"
Please let me know if you need additional information.
XanderBakker
Hi kclark_SubTelForum ,
Can you also post the code you tried?
KieranClark
Yes, the following has returned the field not found error:
var cityname = $feature["STF_Cable_DBO_tblLanding_City"]; // read out the city
var sql = "Cable_Landings_Export_City" + " = " + cityname; // create query
var table = FeatureSetByName($map, "LandingPlusCableTable"); // get access to table
var result = "";
if (cnt == 0) {
    // no records found
} else {
        txt = TextFormatting.NewLine + " - " + All_Cables_Table_Export_SystemName; // use the correct field name from the table
        result += txt;
return result;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Sorry, how do you get it to post with all the nice color coding and such like you had?
XanderBakker
Hi Kieran Clark ,
To get the syntax highlighting you can use JavaScript highlighter:
In More, select Syntax Highlighter:
Next select "JavaScript":
Insert your code.
As to your question, I am not sure if your field names are really called this way (it might show the Alias). One thing that is wrong is line  16:
... should be:
        txt = TextFormatting.NewLine + " - " + record.All_Cables_Table_Export_SystemName;
Note the "record." before your field name.
KieranClark
var result = "";
if (cnt == 0) {
    // no records found
} else {
        txt = TextFormatting.NewLine + " - " + record.All_Cables_Table_Export_SystemName; // use the correct field name from the table
        result += txt;
return result;
I made the change to line 16 as you mentioned, but am still getting the error. As for the field names, I was specifically using the actual field name and not the Alias. Should I be using the Alias instead?
KieranClark
Ok, I've made some progress. In ArcGIS Online, I manually grabbed what each table/field is named as seen by the online system. This differs a bit from what I'd been seeing in ArcGIS Pro. The new entries with the correct field names are as follows:
var cityname = $feature["STF_Cable_DBO__tblLanding_City"]; // read out the city
var table = FeatureSetByName($map, "subcablemapbackup_gdb - LandingPlusCableTable"); // get access to table
var result = "";
if (cnt == 0) {
    // no records found
} else {
        txt = TextFormatting.NewLine + " - " + record.All_Cables_Table_Export_SystemN; // use the correct field name from the table
        result += txt;
return result;
However, I am now getting a new error:
"Execution Error:Expected "!=", "(", "*", "+", "-", "/", "<", "<=", "<>", "=", ">", ">=", "AND", "OR", [ \t\n\r], or end of input but "A" found."
Progress! So I think we're close but I'm not sure what this error is referring to. I'm finding most of these errors to be extraordinarily unhelpful and non-specific.
XanderBakker
Hi kclark_SubTelForum ;
Sorry my bad. Have a look at line 2. Since the city name is a text it should be included in quotes:
var sql = "Cable_Landings_Export_City" + " = '" + cityname + "'"; // create query
var result = "";
if (cnt == 0) {
    // no records found
} else {
        result += txt;
return result;
KieranClark
New error: Execution Error:Runtime Error: Variable must be declared before it is used..
I'm not seeing any variables that aren't declared, though?
