Unable to save the MXD using external python script.
2118
6
07-03-2019 09:16 AM
krishmandali
I am writing a small automation to create a view, register the view in Geo database and publish it as a service. So far good with creating a view and register with Geo database but I am trying to save the mxd before publishing it and its not working out. I saving the registered view in following ways and not working
mxd = arcpy.mapping.MapDocument("C:\GIS\testfile.mxd")
Error: AssertionError: Invalid MXD filename.
mxd = arcpy.mapping.MapDocument("CURRENT")
Error : RuntimeError: Object: CreateObject cannot open map documen
RandyBurton
Did you try:
mxd = arcpy.mapping.MapDocument(r"C:\GIS\testfile.mxd")
The r before the quoted text of the file name will cause Python to interpret the string as raw text.  Otherwise, it would see the \t as an escaped tab character.
krishmandali
@Randu Burton, Thanks for you're reply. I tried you're suggestion but its not working giving me the same error as "AssertionError: Invalid MXD filename.".
Just for you're information there is no file with name "testfile.mxd" all I am trying to save the view as MXD which is not working.
RandyBurton
Then perhaps:
mxd.saveACopy(r"C:\GIS\testfile.mxd")‍‍
See MapDocument for more info as you can specify the version format.  There is also save().
krishmandali
I am not even getting to that point. Creating MXD object itself is getting error.
RandyBurton
Perhaps if you could share a bit more of what you are doing would be helpful.
Here's a bit of an example of working with an mxd document (in this case to make adjustments to the visibility and transparency of some map layers):
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
# or if inside ArcMap:
df = arcpy.mapping.ListDataFrames(mxd, "County Maps")[0]
# ListLayers (map_document_or_layer, {wildcard}, {data_frame})
for lyr in arcpy.mapping.ListLayers(mxd, "Lakes", df):
    if lyr.description == "USGS Lakes":
        lyr.visible = True
        lyr.transparency = 50
mxd.save() # save the document with changes
# or
mxd.saveACopy(r"C:\GIS\testfile.mxd") # save the changes to a new document
del mxd‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In line 3 or 4, you are opening an mxd to work with.  This can be a previously saved document, or the current one opened in ArcMap.  Then make your changes to the document.   And in lines 16 or 18 you are saving the changes to either the original document or a new document.
krishmandali
Hi Randy,
Here is my code
import arcpy
arcpy.env.workspace = r"Database Connections\Connection to SVTHCPHDW.sde"
arcpy.CreateDatabaseView_management("Database Connections\Connection to SVTHCPHDW.sde","Testagain","SELECT TOP (1000) [K_And_FW_key]       ,[zip]       ,[Shape]  ,[GeographyBaseline]       ,[Year]       ,[geography_key]       ,[DP05_0033]       ,[DP05_33E_EstNote]       ,[DP05_33E_Est]       ,[DP05_33E_ErrMgn]       ,[DP05_33E_ErrMgnNote]       ,[DP05_33PE_Pct]       ,[DP05_33PE_PctNote]       ,[DP05_33PE_PctErrMgn]       ,[DP05_33PE_PctErrMgnNote]       ,[DP05_0034]       ,[DP05_34E_EstNote]       ,[DP05_34E_Est]       ,[DP05_34E_ErrMgn]       ,[DP05_34E_ErrMgnNote]       ,[DP05_34PE_Pct]       ,[DP05_34PE_PctNote]       ,[DP05_34PE_PctErrMgn]       ,[DP05_34PE_PctErrMgnNote]       ,[DP05_0035]       ,[DP05_35E_EstNote]       ,[DP05_35E_Est]       ,[DP05_35E_ErrMgn]       ,[DP05_35E_ErrMgnNote]       ,[DP05_35PE_Pct]       ,[DP05_35PE_PctNote]       ,[DP05_35PE_PctErrMgn]       ,[DP05_35PE_PctErrMgnNote]   FROM [DWAcs].[rpt].[Pivot_ZipCode_Acs5DP05_GISTest]")
print "view created sucessfully"
inTable = r"Database Connections\Connection to SVTHCPHDW.sde\Testagain"
oid_field = "OID"
oid_field = "K_And_FW_key"
shape_field = "Shape"
geometry_type = "POLYGON"
sr = arcpy.SpatialReference(4326)
in_extent = ""
arcpy.RegisterWithGeodatabase_management(inTable, oid_field, shape_field,
                                         geometry_type, sr, in_extent)
mxd = arcpy.mapping.MapDocument("CURRENT")//This one is creating error
I don't have mxd file previously saved in location. Need to save it after I registered the view with Geo Database.(on fly)
