problem of using arcpy.polyline creat line
1266
06-28-2019 08:21 PM
lmzh
I  have a python script that was get coordinate points (Longitudinal and latitudinal coordinate ) from excel and writing them to an arcpy.Array and then writing the array to an already existing feature class as a polyline.  but line created  finished offset the point ,and vertices of  creating line  less than numbers of points.
JoshuaBixby
MVP Esteemed Contributor
You appear to be using the original ArcPy cursors, as opposed to the ArcPy Data Access cursors that were introduced in 10.1.  I recommend switching to the DA cursors and then re-post your question if you are still having issues:  Accessing data using cursors—Help | ArcGIS Desktop
LukeWebb
I always make my polylines like this, so no idea if this will help:
polyline=arcpy.Polyline(array)
row.setValue(shapename, polyline)
For the offset, you probably need to include a spatial reference:
spatref_epsg = 4326   #https://spatialreference.org/ref/epsg/wgs-84/
arcpy.CreateFeatureclass_management(out_path=folder, out_name=shapename,geometry_type='POLYLINE', spatial_reference=arcpy.SpatialReference(spatref_epsg))
lmzh
thanks, offset reason is lack of spatial reference indeed.
