Barcode Scanning - Multiple parameters
694
06-25-2019 08:54 AM
RonParis
Is it possible to take attributes stored within a QR/Barcode, and split to different fields within a form?
For example, QR code holds the text value:
Text1, Text2, Text3
I want to take these and assign as follows:
Question1: Text1
Question2: Text2
Question3: Text3
I understand that substr() function exists, but I need to take whole words.
TIA
by Anonymous User
Not applicable
Hi Josh,
Have you tried setting the barcode question to minimal, so that the text input box that will contain the entire text string of the barcode is not displayed in the form, and then use 3 following text questions with calculations, or you can use hidden calculate questions if you prefer none of them displayed on the form. You can then try using a regex or substr functions to pull the values you want out of the barcode question string.
Phil.
