map series by attribute series
1618
06-24-2019 12:30 PM
QuanCui
I am using GIS Pro 2.3.
How can I draw multimaps (4 rows * 3 cols) in one layout,  each map displays one column from one attribute table? All layers, design of the multimaps are the same.
First I thought about map series, but it seems only to cut a big map to series parts -  not what I want.
Thank you.
TomBole
Hello Quan Cui,
I'm assuming that by "displays one column" you are referring to how the layer is symbolized.
You will need to create 3 separate maps where each map uses a different column to symbolize the layer. You can then add each map to the layout.
Hope this helps,
Tom
MarcelSt-Germain
Not sure if it’s that you want but, do you need to have, in a page layout, a series of maps base on the same dataset but, each one link to is one extend driven by the map series?
