“This layer’s network data source does not support directions.” Error in ArcPro
3509
06-24-2019 10:37 AM
by Anonymous User
Not applicable
I received the following error in ArcPro (2.2.3) while trying to generate Directions for my Network Dataset: “This layer’s network data source does not support directions.” I can’t find any documentation about this - any ideas how I can manipulate my dataset to fix this?
Thanks!
KoryKramer
Esri Community Moderator
by Anonymous User
Not applicable
Hi Kory Kramer‌,
I don't see an answer at the link you provided. Would you be able to point me in the right direction? Perhaps I'm not searching the correct terms/not looking in the right place. Thanks!
JaySandhu
The directions capabilities are set in the network dataset. Does you street data feature class have a street name field? If yes, then you can update the network dataset properties using ArcMap. The ability to configure the network dataset for directions is not available in ArcGIS Pro yet, but coming shortly.
You can read more about this here:
https://desktop.arcgis.com/en/arcmap/latest/extensions/network-analyst/setting-directions.htm
Jay Sandhu
