WAB- Data Aggregation Widget
381
06-21-2019 07:22 AM
NatalieO_Toole1
Hi - I'm using WAB version 2.5. When i add the version 2.12 Data Aggregation widget it gives the following error:
"Create widget setting page error"
Any ideas on how to fix this error please?
Nat
DerekLaw
Esri Esteemed Contributor
Hi Natalie,
Just to clarify, are you using Web AppBuilder for ArcGIS Developer Edition v2.5 and trying to add a widget that was built on a later release of Web AppBuilder? My guess is the widget may be referencing files/components from a more recent release of the ArcGIS API for JavaScript API and they may be missing in the earlier release.
About release versions—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
FYI, Web AppBuilder v2.5 uses the JavaScript API v3.21 while Web AppBuilder v2.12 uses the JavaScript API v3.28.
I suggest you upgrade your Web AppBuilder for ArcGIS Developer Edition to v2.12.
Hope this helps,
