Survey123 Relevant syntax Question
2491
06-20-2019 07:19 AM
JerroldRentz1
Hi, I'm fairly new to Survey123 and am having an issue with a relevant syntax... I have a select multiple question where if you select answer "A", a yes or no question pops up. What I would like to do is if the answer is "No" I would like a text box to pop up for an additional description.
I cannot seem to get this to work... could someone please assist me with this? I feel like this should be an "If" syntax but I cannot seem to get it to work...
Thanks!
Tags (1)
BrandonArmstrong
Hi Jerrold,
It sounds like you would just need a relevant statement to determine whether a text description would appear or not after selecting 'yes' or 'no'. You can add a text question after the yes/no question and in the relevant column for the text question input
${yesno}='no'
I have attached an XLSForm which demonstrates this method.
Please let me know if this is what you were looking to accomplish.
Best,
Brandon
BrandonArmstrong
Hi Jerrold,
${yesno}='no'
Best,
Brandon
JerroldRentz1
Well, I grossly overthought this. Thank you Brandon it works well now.
