Inaccuracy in creating nodes/lines
925
06-19-2019 07:51 AM
MatthewHerrell
When editing a feature class by adding a node, I will select, via my cursor, its desired location only for it to offset the symbol for the node about 2 feet northwest. Obviously, I would like node depicted where I click. Any solutions??
David
by Esri Contributor
You said the symbol draws to the north west. Do you actually mean label? When you click, ArcGIS Pro should create a point in that exact spot. If that point was identified as B3, then there would be a label appearing to the northwest of the point identifying that point as B3. Northwest is the default location for labels in ArcGIS. You can modify it to display where ever you like.
If there isn't any confusion about symbols and labels, then I have no idea why a point would get created in a different location from where you clicked.
