Changing default value feature layer created using ArcGIS Solutions Deployment
1005
06-17-2019 07:32 AM
RichClocker
Is it possible to update a default value on a feature layer that was created using ArcGIS Solutions Deployment?  I am creating a citizen problem reporter application (hosted in AGOL) and would like to change the default value for the "Visible to the public" field to "No".
I have added one of the feature layers to Pro to make this change.  However, the field properties are grayed out and not editable as can be seen in the screen shot attached.
Thanks in advance for any help.
Jake
AriLukas
Were you able to get this figured out?
