Excel Custom Report Template
935
06-17-2019 12:43 AM
ThomasPerriment
I'm interested in importing my Survey123 csv/excel outputs into other programs, however with data structures of the programs not aligning very well with how data is actually recorded in the field, I'm keen to find out how I could export from Survey123 to excel using field codes to determine the order of export (ie. if I have Column A then Column B in my Survey123 output, could I restructure to Column B then Column A in an export).
Is this possible? Or does anyone know if any workarounds?
Many thanks,
Thomas
JamesTedrick
Esri Esteemed Contributor
Hi Thomas,
The export option from the Survey123 website does not have the capability to re-order the columns.
