How to use query in arcpy.Append_management
3476
06-13-2019 07:01 PM
deleted-user-yC5VkbyXzrQR
it's weird that the arcpy.Append_management function does not have any arguments for SQL Expressions.
Does anyone know a way around this ?
Below is my code. Basically I want to take a feature layer with a sql statement and put it in a sde.
Would I have to use arcpy.MakeFeatureLayer_management() then append?
And I want to ensure that the expression only grabs 1 feature, if there are more than 1 features trying to append it will fail. Would I do this in the validation or could I do this in the script ?
import arcpy, os, datetime, sys
scratchLoc = arcpy.env.scratchFolder
cs= arcpy.SpatialReference(102003)
xmlLoc = r"\\......_Scripts\KMZtoInvBdy\INV_BDY.XML"
gdbname = r"prjbdy_scratch.gdb"
fcLoc = r"\prjbdy_scratch.gdb\inv_project_boundary"
cntylyr = r"......\Default.gdb\AA_counties_SpatialJoin"
mxd = "CURRENT"
date = datetime.datetime.now()
dateprj= date.strftime("%d/%m/%Y")
fl = arcpy.GetParameterAsText(0)
Expression = arcpy.GetParameterAsText(1)
if Expression == '#' or not Expression:
    Expression = "" # provide a default value if unspecified
Project_Name = arcpy.GetParameterAsText(2)
Project_Status = arcpy.GetParameterAsText(3)
if Project_Status == "Operating":
	Project_Status = "OPE"
elif Project_Status == "Prospecting":
	Project_Status = "PRO"
elif Project_Status == "Development":
	Project_Status = "DEV"
elif Project_Status == "Interconnection Area":
	Project_Status = "INT"
Project_Tech = arcpy.GetParameterAsText(4)
if Project_Tech == "Wind Farm":
	Project_Tech = "WND"
elif Project_Tech == "Solar Plant":
	Project_Tech = "SOL"
elif Project_Tech == "Thermal Plant":
	Project_Tech = "THM"
elif Project_Tech == "Battery Storage":
	Project_Tech = "BAT"
elif Project_Tech == "Co-Generation":
	Project_Tech = "COG"
elif Project_Tech == "Desalinization Plant":
	Project_Tech = "DES"
Primary_Expasion = arcpy.GetParameterAsText(5)
if Primary_Expasion == "Primary":
	Primary_Expasion = 1
elif Primary_Expasion == "Expansion":
	Primary_Expasion = 2
MapFeature = arcpy.GetParameterAsText(6)
if MapFeature == "Display":
	MapFeature = 1
elif MapFeature == "Do Not Display":
	MapFeature = 0
arcpy.CreateFileGDB_management(scratchLoc,gdbname)
gdbloc = os.path.join(scratchLoc,gdbname)
arcpy.ImportXMLWorkspaceDocument_management(gdbloc,xmlLoc)
arcpy.Append_management(fl,scratchLoc + "\\" + gdbname + r"\inv_project_boundary","NO_TEST",Expression)
#be able to import any type of feature eg.shapefile,fc,geojson
#different conversions
#Calculates Area
arcpy.AddGeometryAttributes_management(scratchLoc + fcLoc,"AREA_GEODESIC","","ACRES",cs)
arcpy.MakeFeatureLayer_management(scratchLoc + fcLoc, "prjbdy_Layer")
arcpy.MakeFeatureLayer_management(cntylyr, "cntlyr_Layer")
arcpy.SelectLayerByLocation_management("cntlyr_Layer","INTERSECT","prjbdy_Layer")
scur = arcpy.SearchCursor("cntlyr_Layer")
try:
	for row in scur:
		cnty_name = str(row.getValue("NAME"))
	statename = str(row.getValue("STATE_ABBR"))
	scur2 = arcpy.SearchCursor("prjbdy_Layer")
	for row in scur2:
		Acres = row.getValue("AREA_GEO")
	del scur
	del scur2
except:
	arcpy.AddMessage("***Can't find County***")
#arcpy.Append_management(scratchLoc + fcLoc, scratchLoc + "\\" + gdbname + r"\inv_project_boundary","NO_TEST")
ucur = arcpy.da.UpdateCursor(scratchLoc + "\\" + gdbname + r"\inv_project_boundary",["PROJECT","PROJ_STATUS","TECH","MAP","PRIMARY_","DATE_REVISED","COUNTY","STATE","ACRES"])
try:
	for row in ucur:
		row[0]= Project_Name
		row[1] = Project_Status
		row[2] = Project_Tech
		row[3] = MapFeature
		row[4] = Primary_Expasion
		row[5] = dateprj
		row[6] = cnty_name
		row[7] = statename
		row[8] = Acres
		ucur.updateRow(row)
	del ucur
except:
	arcpy.AddMessage("***Can't Add County***")
arcpy.AddMessage("***RESULTS***")
arcpy.AddMessage(Acres)
arcpy.AddMessage("Revised Dated: " + dateprj)
arcpy.AddMessage("County, State: " + cnty_name + ", " + statename)
arcpy.AddMessage("Adding to IS_MAIN.DBO.inv_project_boundary")
arcpy.Append_management(scratchLoc +r"\kml_scratch.gdb" + r"\inv_project_boundary", r"..........._project_boundary")
arcpy.AddMessage("Finished adding to")
JakeSkinner
Esri Esteemed Contributor
Hi Adam,
Yes, this correct.  You will then pass the Feature Layer as the input for the Append.  Before doing so you can execute Get Count function and only run the Append if the count is equal to one.  Ex:
arcpy.MakeFeatureLayer_management(fc, "fLayer", "OBJECTID = 1")
result = arcpy.GetCount_management("fLayer")
count = int(result.getOutput(0))
if count == 1:
    arcpy.Append_management("fLayer", target",....)
JakeSkinner
Hi Adam,
if count == 1:
Thanks Jake.
Thats exactly what I did. It worked!
