Share a Map Image Layer not available?
4458
7
06-13-2019 01:00 PM
MarquesMunson1
I am attempting to publish a map image layer from Pro but the options under "Layer Type" only shows Feature, Tile and Vector Tile. Is there a way to get this option? I have attached a screenshot of my Share as a Web Layer pane.share as a web layer pane missing map image layer option
KoryKramer
Esri Community Moderator
Are you connected to an Enterprise portal or ArcGIS Online?  If Online, you can't publish a map image layer.
https://pro.arcgis.com/en/pro-app/help/sharing/overview/map-image-layer.htm
KoryKramer
MarquesMunson1
I am connected to ArcGIS Online. I have a feature service with multiple layers that I wanted to have in my web application and am looking to an effect of this example. Are there any alternatives?
KoryKramer
Publishing to ArcGIS Online would give you a feature layer, and that would have a REST endpoint that you could work with in your own custom apps.  You'd be working with a feature layer and its capabilities as opposed to a map image layer.
https://developers.arcgis.com/javascript/latest/sample-code/layers-featurelayer/index.html
MarquesMunson1
Last question, the last sentence on the screenshot that you shared. How can I find what privileges are needed to publish server-based layers?
MarquesMunson1
Everything is working now, thanks for your help!
AliAzzouhri1
Good
