SQL server client
4309
06-10-2019 01:11 PM
SLouq
by MVP Alum
Where can I download SQL Server Client from. I need to make a database connection to our SDE connection and
I keep getting the error message.
'Failed to connect to the specified server. Connection was attempted with an older version of SQL Server Client communications software that is not supported.'
I googled this error message and there is a technical article which states you need to install SQL Server Client on your computer.
https://support.esri.com/en/technical-article/000010759
AlexanderThurstlic
Hi Scott,
SQL Server clients for Microsoft Windows and Linux are distributed by Microsoft.
https://docs.microsoft.com/en-us/sql/connect/odbc/download-odbc-driver-for-sql-server?view=sql-serve...
SQL Server clients for Windows are also available on My Esri. You must install a client that is the same version or a newer version than the SQL Server database to which you want to connect.
Supported clients for different SQL Server releases are also included here:
http://desktop.arcgis.com/en/system-requirements/latest/database-requirements-sqlserver.htm#ESRI_SEC...
AlexanderThurstlic
Hi Scott,
SLouq
by MVP Alum
Thank you Alexander!
