I am viewing the database for a survey I created in Survey123 Connect and the column headers are my question labels instead of field names. The only time the column header appears as it should is if the question type is "hidden". Does anyone know how I can fix this?
Solved! Go to Solution.
Try defining an alias in the bind::esri:fieldAlias column:
