script to list domains and FC, Tables associated
1231
06-07-2019 04:53 AM
JoseSanchez
Hello everyone,
I am looking for a script that lists all the domains and Feature Classes or tables where the domain is referenced.
Also I am interested also in passing as a parameter a specific domain name and listing all Feature Classes and Tables where the domain is referenced.
RandyBurton
Here are a couple of scripts that I have used.  This one reads the domain information:
import arcpy
dbName = r"C:\path\to\file.gdb" # your geodatabase path
print dbName
print
domains = arcpy.da.ListDomains(dbName)
for domain in domains:
    print
    print('Domain name: {0}'.format(domain.name))
    if domain.domainType == 'CodedValue':
        coded_values = domain.codedValues
        for val, desc in sorted(coded_values.iteritems()):
            print('{0} : {1}'.format(val, desc))
    elif domain.domainType == 'Range':
        print('Min: {0}'.format(domain.range[0]))
        print('Max: {0}'.format(domain.range[1]))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This one reads the field information.  Note specifically the field.domain property.
import arcpy
from arcpy import env
# Set the current workspace
env.workspace = r"C:\path\to\file.gdb" # your geodatabase path
print env.workspace
print
# Get the list of standalone tables in the geodatabase
tableList = arcpy.ListFeatureClasses() # for features
# tableList = arcpy.ListTables() # for tables
print tableList
for table in tableList:
    print
    print table
    dbTable = env.workspace + "\\" + table
    fieldList = arcpy.ListFields(dbTable)
    print '\t['
    for field in fieldList:
        # print("\t{0} is a type of {1} with a length of {2}"
        #     .format(field.name, field.type, field.length))
        # Print field properties
        # print("Name:  {0}".format(field.name))
        # print("\tBaseName:    {0}".format(field.baseName))
        # print("\tAlias:       {0}".format(field.aliasName))
        # print("\tLength:      {0}".format(field.length))
        # print("\tDomain:      {0}".format(field.domain))
        # print("\tType:        {0}".format(field.type))
        # print("\tIs Editable: {0}".format(field.editable))
        # print("\tIs Nullable: {0}".format(field.isNullable))
        # print("\tRequired:    {0}".format(field.required))
        # print("\tScale:       {0}".format(field.scale))
        # print("\tPrecision:   {0}".format(field.precision))
        print '\t["' + field.name + '",',
        if (field.type == "String"):
            print '"TEXT", ',
            print '"' + str(field.length) + '",',
        else:
            print ("\"{0}\", ".format(field.type).upper()),
            print '"#",',
        print '"' + field.aliasName + '",',
        if len(field.domain):
            print '"' + field.domain + '"],',
        else:
            print '"#",',
        print '"#"],' # Default
    print '\t]'
# Fields: [ 0:Name, 1:Type, 2:Size, 3:Alias, 4:Domain 5:Default ]  use "#" for blanks
# Field type is returned as:
# SmallInteger, Integer, Single, Double, String, Date, OID, Geometry, Blob‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
See also:
ListDomains
ListFeatureClasses
ListFields
