Creating (Circle) Polygon with Specific Area Size
1978
06-06-2019 12:06 PM
KioshiMishiro
I am wondering if the ArcMap (10.6) or ArcGIS Pro (2.3.3) allows us to create circle polygon with setting specific area-size, instead of radius? Thank you in advance.
JoshuaBixby
MVP Esteemed Contributor
The GeoNet Resource Hub is for asking questions about GeoNet itself, not general questions about Esri software.  Sharing with Analysis‌.
Is this something that will be repeated a lot?  Are you using the GUI and an edit session?
DuncanHornby
MVP Notable Contributor
If you know the area you want then you can work out the radius that you need to create it
Area of circle = PI * r^2
Therefore to know radius the equation is
r = SQRT(area/PI) where SQRT means Square Root.
So for example if you want a circle that is exactly 200m2 then the radius is SQRT(200/PI) which is 7.978m to 3 decimal places.
Now you know the radius just feed that into a buffer tool.
JoshuaBixby
Are you thinking of a GUI tool/interface?
