invalid network dataset type error in Create Template from Network Dataset
2082
06-04-2019 09:25 AM
RaeganYoung
Trying to run "Create Template from Network Dataset" in ArcMap 10.6.1 and continually getting "030070 Invalid network dataset type" for my input dataset. I have tried .nd mostly, but also used "Make Network Dataset Layer" and the layer output gets the same error. ESRI help says the input data type should be "Network Dataset layer".
Don't understand what I am missing here are would appreciate some help.
Thanks all,
r
MelindaMorang
That tool does not work with shapefile network datasets (the ones with the .nd extension).  You must use a file geodatabase network dataset.
MelindaMorang
RaeganYoung
Wow! Would not have thought of that, I wonder if that the same for iterators? I have been having issues with iterate network dataset not finding my networks?
Thanks so much!!!
