AddCodedValueToDomain, how to add an empty string value
4139
7
06-01-2019 01:11 PM
JonHall
Here's a code snippet we're using to create a domain, and add values to it, for the purpose of constraining street name prefix directionals:
arcpy.CreateDomain_management(GeodatabaseName, "StreetNameDirectional", "prefix directional of parsed street name", "TEXT", "CODED")
domDict = {"N":"North", "S": "South", "E": "East", "W": "West", "NE": "Northeast", "NW": "Northwest", "SE": "Southeast", "SW": "Southwest"}
for code in domDict:
 arcpy.AddCodedValueToDomain_management(GeodatabaseName, "StreetNameDirectional", code, domDict
In ArcMap's Table interface, while editing a row, the 8 values and descriptions appear in the combo-box list for fields that have that domain applied. So far, so good.
However, after a row has a value of "N" in that field, there is no way to change it from "N" back to none, i.e. an empty string, using the combo-box list
I can use the Field Calculator to set it equal to "", an empty string, but that's not an intuitive solution. I want an empty string value with a description of "none".
In the ArcCatalog tree, Database Properties, Domain tab, I tried adding a 9th row to the StreetNameDirectional domain with no value, and Description = "None". Click Apply, looks okay, close ArcCatalog, and there's no 9th row of domain values & descriptions.
Adding two double-quotes as the 9th row Value for the domain, with Description = "None", only succeeds in adding a pair of double-quote ASCII characters in the prefix directional field.
I want to do this programmatically, using arcpy.AddCodedValueToDomain_management, but I can't even do it through the ArcCatalog user interface. I can't find anything documented RE: including an empty string in a coded value domain.
I should add a related annoyance, that's more trivial: The field is nullable, so "<Null>" appears at the top of the combo-box list.  I don't want the user to choose a null value, I want an empty string value; and ArcMap won't let you select <Null> from the list, throwing an error that "This field will only store string values with up to 2 character(s)".
Thanks in advance for any assistance you may provide.
RandyBurton
I don't think it is possible to have a coded value domain where the "code" is None/Null.  To have an option of "<Null>" show up in the domain selections (where the actual code stored is a NULL value), you need to set the field using the domain to "Allow NULL Values".
directional domain <Null> examplefield properties
Typically, I set the default value of my fields using domains to use a code like "?" or "NA".  These would then display a description of "None", "Missing" or a prompt to "Make a selection".  I would then set allow null values to "No".  I would set any fields with a null to this default value.
Hope this helps.
JonHall
Randy, thanks for the response. Yes, "I don't think it is possible to have a coded value domain where" the code is an empty string.  That's why I posted this question.
ESRI hasn't documented whether it is or isn't possible, but trial and error indicates that it's not.
I suspect that our workgroup has mis-used the isNullable option, with the intention of allowing empty values. A field that isNullable can be deleted from the attribute table.  The field is REQUIRED, whether it contains values, or not.
My understanding is that a database null value is quite different than storing a 6-characer string, "<Null>", which is what ESRI's ArcMap table user interface is attempting, when it throws the error that "This field will only store string values with up to 2 character(s)".  I may start a separate thread on that topic, but hate wasting time spitting into the wind, complaining about ESRI software, unless it's a stupid-user-problem and I might learn the error of my ways from the GIS community.  If I solve either issue, I'll post the workaround or solution.
RandyBurton
We may be in agreement, but to be clear, "<Null>" is not a six-character string or the description of a coded value.  It is the file geodatabase's representation that a null value is in the field.  When it appears in a drop-down list, like a display of a database table in edit mode or an application like Collector, when "<Null>" is selected, a null value will be placed in the field.
JonHall
Right, Randy, that's the behavior I expected, but ArcMap throws that error
message, and no null value is saved in the field.
RandyBurton
What type of geodatabase are you working with?
JonHall
The file geodatabase schema, created with arcpy script, defining the fields
and domains, has been loaded into enterprise SDE on SQL Server.
Matt-Goodman
I am also interested in this. Using an SDE domain, is there a way to allow the user to choose blank/empty string from the domain pick-list instead of choosing null? I want the actual data/value stored to be an empty string....not null.
Example: when a road name has a pre-directional (north, east, south, or west) the user would choose the appropriate value from the domain ("N", "E", "S", "W"), but for road names that do not have a pre-directional at all, the user would choose a blank/empty string 'value').
