Create 3D object scene layer package issue
1863
05-31-2019 03:55 PM
iR1
Hi
In arcgis latest update (2.3.3) Create Scene Layer tool, was split into several specific. One of those is Create 3D Object Layer Package, which throws an "ERROR 002102  Unsupported properties set in the layer" when I try to export a layer with its Elevation setting "On the ground" or "Relative to the ground". It allows the export only with the option "At an absolute height".
However the previous generic tool in older versions, would export the layer with no complains.
Is this normal or is there an issue with the new tool?
Thank you.
Andrew--Johnson
This is expected behavior and has always been the behavior for multipatch feature layers. They must use an absolute height elevation setting prior to being run through the Create 3D Object Scene Layer Package tool.
thanks,
Andrew
iR1
Thank you for clarifying.
