IIF expression for attribute assistant
1358
05-31-2019 10:17 AM
BrianHumphries1
I am trying to calculate a field using the attribute assistant using the Dynamic Value table.
I want to check the MainHeading Field and if the value of the field falls in between two values Calculate Yes or NO
If the value is between 166 and 195 I want the field to be populated with a Yes
If the value is not between those values I want to field the populated with a NO
Below is the what I have tried, but I keep getting the same results as YES for all values even the ones that are not in between the 166 and 195 range.
IIF([MainHeading] >= 166 & [MainHeading] <=195, "YES", "NO")
I am sure I have something wrong but I cannot figure it out.
I know someone on here can solve this.
RobertBorchert
Honored Contributor
Is mainheading an integer, double, or string?
If it is a double
IIF([MainHeading] >= 166.0 & [MainHeading] <=195.0, "YES", "NO")
 if it is a string
IIF([MainHeading] >= "166" & [MainHeading] <="195", "YES", "NO")
Are any of the Mainheadings <Null>  if so try putting something in there
Now the dumb question:  Do you have any values less than 166 and or greater than 195
BrianHumphries1
Thanks, Robert
I was able to figure out what I was doing wrong. I wanted to be able to get the direction of the main to figure out the downstream invert of a manhole to auto-populate the downstream invert of my main. To do this I added a couple of fields to store the angle and the heading.
MainHeading to store the Angle
DSHeading to store the Flow Direction
I ended up using this as my expression to store the Direction of flow in the DSHeading Field.
IIF([MainHeading]<=22.5, "S", IIF([MainHeading]<=67.5, "SW", IIF([MainHeading]<=112.5, "W", IIF([MainHeading]<=157.5, "NW", IIF([MainHeading]<=202.5, "N", IIF([MainHeading]<=247.5, "NE", IIF([MainHeading]<=292.5, "E", IIF([MainHeading]<=337.5, "SE", IIF([MainHeading]<=360, "S", "<Null>")))))))))
