Error SSLRead failed
1447
05-29-2019 01:06 PM
PamelaLandy
Hi, I am trying to connect survey123 to my gis portal (enterprise 10.6) but I get this error in apple iOS devices. When you do the same in Android tablets it connects correctly
JamesTedrick
Esri Esteemed Contributor
Hi Pamela,
Error code -9842 is Client Certificate requested.  Could you check your web adaptor's setting in IIS configuration (SSL Settings > Client certificates) - is this set to "Accept"?  If so, can this be changed to "Ignore"?
JamesTedrick
Hi Pamela,
PamelaLandy
Thank you so much  James Tedrick‌.
