Can I generate a survey report based on a selection of fields?
598
05-27-2019 02:32 PM
KileyHeaps
I am hoping to find an easy way to generate a survey report that includes the following fields for each question: 'type', 'name', 'label', and 'relevant' (if applicable).
I attempted this process by going to the particular survey page, clicking on data, and then the report tab. The output included the 'type' and 'label' field, but I am not sure how to add additional information to the template.
I used Survey123 for my Graduate research project and I need to include the full list of questions I asked in the survey to the appendix of my thesis. Hoping for a quick and painless way to do this. I have some experience with Python if this helps.
Thanks in advance!
JamesTedrick
Esri Esteemed Contributor
Hi Kiley,
You can easily access your form setup using Survey123 Connect.  If you created the form on the Survey123 website, download & install Survey123 Connect from Survey123 for ArcGIS Resources | Downloads, Training, Videos & Documentation .  Log in and download your survey to your computer.  When previewing the survey, click the folder icon - the XLSX file is a representation of your survey that you can use for your report.
