Output table in gdb not showing its contents
1101
05-27-2019 10:34 AM
sotokan80_
I am using ArcGIS 10.4.1 and arcpy. I am facing an issue when creating a table in a gdb using GenerateNearTable_analysis tool. The output table does not show its contents. This only occurs if the workspace is a geodatabase. If i restart arcmap it shows its contents but thats not the point since my code crashes at that point. Any ideas?
DanPatterson_Retired
Your code would help with solving the problem I suspect
