Data Reviewer check for matching attributes
498
05-21-2019 07:19 AM
Labels (3)
by Anonymous User
Not applicable
We are currently writing data reviewer scripts to run against data we are capturing for our business which is a Water Company in the UK. One check we would like to run is for every water main laid against a specific job code that all of the features in the extent have the same job number attribute saved against the water main.
For example if we lay 6 mains each main should have a job number attribute of C1234
Any help would be much appreciated to construct the query through data reviewer
WillWalter1
This may be an instance where a visual check would be effective.  Generate a symbolization on the project number field and you should be able to quickly identify areas with outlining values.
