Why does this toolbox script fail the second time? NameError: global name 'arcpy' is not defined
1159
05-21-2019 05:51 AM
FredSpataro
Hi All,
Really simple script attached to a toolbox tool:
  • has a wrapper class to convert logging to arcpy.AddMessage.
  • no input or output parameters
  • has a main function that adds a single message to the window
  • imports arcpy and logging only
  • runs successfully the first time
  • fails every time after that until the arcmap/arccatalog app is restarted
  • ArcGIS Desktop 10.6.1
Zip file attached with script and toolbox. Here's the script:
import arcpy
import logging
class AddMessageHandler(logging.Handler):
    def emit(self, record):
        log_entry = self.format(record)
        arcpy.AddMessage(log_entry)
def main():
    logging.debug("----this is a test----")
if __name__ == '__main__':
    logging.basicConfig(level=logging.DEBUG)
    root_logger = logging.getLogger()
    root_logger.addHandler(AddMessageHandler())
    main()
First run success:
Subsequent runs fail:
Tags (1)
DanPatterson_Retired
Works in Python 3.6.8 within ArcGIS Pro.
Are you using python 2.7?
In any event, give this a shot, which also worked flawlessly
import arcpy
import logging
def main():
    main()
FredSpataro
Yes it's python 2.7, ArcGIS 10.6.1... ArcGIS Server does not support python 3.x, Pro is not an option.
Moving the logging lines does not change the result.  Runs fine the first time, fails the every time after that.
Don't know the differences between the server version and *map or *pro. That leave python 2.7 or server or moving emit out of the class and just calling it
