New Create Locator tool: Customise result output?
935
05-16-2019 03:52 AM
DavidGeorge
With the new Create Locator tool in ArcGIS Pro, is it possible to customise the results output in any way?
I am looking to have the ability to customise the output that is returned in the [Match_addr] field which is used in applications like Collector for ArcGIS to display results when searching for.
With the legacy Create Address Locator it was possible to customise the results output in the [Match_addr] field by customising the XML stylesheet, but this does not seem to be possible with the new Create Locator tool. This does appear to be somewhat limiting compared to the legacy versions.
In addition to this, why does the 3 digit country code get returned in the results? This is not necessary if you are building a locator for a single country, can this be turned off?
Tags (3)
ShanaBritt
David:
It is not possible to configure the output label or turn off the country code. However, we will evaluate the issue with "USA" being added to the end of the output label if country code was not part of the field mapping.
