Auto populate field data in one table using the reference of other table
690
05-14-2019 12:17 AM
yoganandhamgangadharan
I need to auto populate field data in one table using the reference of other table.  I tried this using some sql scripting in arcpy. using the script I was able to pull the data from table but not modifying of the data.
import arcpy
# Use a connection file to create the connection
egdb = r'C:\Users\mlgsadmin\AppData\Roaming\ESRI\Desktop10.6\ArcCatalog\Connection to 10.72.15.186.sde'
egdb_conn = arcpy.ArcSDESQLExecute(egdb)
table_name = 'SDE.BPPL_Overall_Status'
field_name = 'Status'
sql = '''
UPDATE SDE.BPPL_Overall_Status
 SET BPPL_Overall_Status.Clearing = Cleraing_ROW_0_175_Km.STATUS
 from BPPL_Overall_Status
 Inner Join Cleraing_ROW_0_175_Km
 ON BPPL_Overall_Status.Start_mts=Cleraing_ROW_0_175_Km.Start_mts
'''.format(field_name, table_name)
egdb_return = egdb_conn.execute(sql)
This was the script used.
JoshuaBixby
MVP Esteemed Contributor
Looking at how you are building the SQL statement, you define table_name and field_name, but neither of those variables are actually being used in the statement.  What do you want the final SQL statement to look like?  And if what you have is what you want, then what do you think is happening with field_name and table_name?
